Ordinarily, when opening the pool, I manually vacuum all the silt and debris to waste and get the pool clean and balanced before using the robot. It's a miserable job that takes hours, so this year I decided (because I'm an idiot, a lazy idiot) not to do the usual manual vacuuming when opening up the pool, and instead I just netted out some of the big debris (leaves, piles of worms) and then put the robot (a Dolphin SX20, same as S100/E20 I think) in to clean it up for me.
That might have been a mistake. For one thing, it very quickly got clogged up with fine silt (this was with the regular basket, not the fine one). Worse, all kinds of debris is now sprouting out from every opening and even the joins between the plastic exterior panels - evidently crud and debris has got everywhere inside the thing once its basket got clogged - and I can't clean it out. I did briefly put it back in the pool and it seemed to still work OK but of course the water was still pretty bad so took it out again (and now attempting to clean up the pool the 'traditional' way!)
Anyway, I guess I know now that using the robot for the initial clean up is a bad idea.
But do you think (one I've got the pool clean) when the robot goes back in, the clean water will flush out the debris from inside the machine? Anyone else had this happen?
