Fiancee's pool again, 14,000 gallons with spa and solar. House built in 1980, so pool is not any older than that.
I did not even realize that pool had copper pipe, most of pipe near pump, heater, and filter is PVC, painted brown, and then black.
Been talking about converting pool to SWG, friend of fiancee' said they did that, and immediately converted back when someone discovered copper pipe. Fiancee' said she had copper and showed me.There is just a stub of copper pipe sticking up on each of the returns to the Spa and to the Pool. No where else, all other plumbing appears to be white PVC, under all that brown and black paint.
So would a pool be built with just copper on the returns? Even plumbing coming out of heater is PVC, until a couple of inches off the ground, where it's copper. And all the suction plumbing is PVC.
Thoughts on any of this?
Thanks in advance,
Jeff
Thanks in advance,
Jeff
