Hey all,
Im back again with a question. My facility is going on 60 years old with original tile flooring, it has aged poorly through its years and has a large buildup of calcium and rust stains.
My initial thought was to acid wash with a 4:1 ratio but the results haven't been as good as i hoped.
I used a straight solution of muriatic, let sit for less than a minute while brushing around and it has seemed to work wonders.
Anytime I use acid I am weary of effects Im not aware of, as I am doing cleaning im thinking “is this going to damage the floor drains?” “Is this a quick fix that will ruin the tile?”
I made sure to flood the floor with water and let fresh water into the drains for a couple minutes.
Anyone in a similar situation have any advice? Am I doing the right thing because it seems to be working well.
Thank you
Thank you
