Hi all, I am in the middle of getting my pool setup, and I am running 2" pvc to hard plumb. My pump is a Tidal Wave 2 speed, and I currently have it setup to be used with my old intex. so, the pump has adapters that screw in and accept the intex flex hoses. I am converting it to the 2" pvc, and will take out the adapters. My question is, what fitting do I need to get that will screw onto the pump? it would be a female thread to a SLP for the pvc.
Also, for unions, shut off valves? Where do you get most of your fittings? pipe, 90° elbows, ect... I can get at my local Menards, but I wanted to use a better shut off valve and union then what they have. Also, what glue do you guys all use? does it matter on brand?
Thanks
Thanks
