Weather was good during application which they finished around noon. Overnight between plaster and polishing the temperatures were cool, probably got to right above freezing for an hour or two in the early morning (forecast low was 43).I have Primera Stone as well that was done 4 years ago. I have not seen or have any hairline cracks such as what I see in your photos. It would seem that the workers polishing it would have noticed or would have tried to polish them out. Was it good weather when they applied it? I would ask the PB or the subcontractor to review it. Are you now filling the pool?
Yes, this is post acid wash. We plan to talk to the contractor about this as well.We did not do primera but regular wet edge but looking at the tile line the plaster looks off too. Isn’t that post acid wash?
They did a full chip out to the gunite.Was this a full chip out of the old plaster down to the gunite or did they do a skim coat?
Yes, they are hard to see now that the pool is full.Well that’s good.
What you’re seeing are shrinkage cracks. They are common in the curing of cement materials and they have many causes but it’s typically due to hydration issues during curing. If cement loses too much water too quickly during the initial curing process, the material can shrink and crack. Too much water in the cement or lubricating a trowel with too much water during hard troweling can add too much water to the surface and that can lead to shrinkage cracks. Once there they will not go away. However, once the pool is full, you will probably not notice them.
Not much you can do about it. They could try sanding the surface more but they’re probably too deep to remove with grinding.
Just something you’re going to have to live with as you will probably be the only person that knows they are there.
