Hi all,
So I noticed today that my swim pure swg display was partially not working. The salt level, amps volts, chlorine , model etc was all showing on the display.
The power light and generating light are not lighting up. Ughhh! Tested levels and the system is producing chlorine and the salt is good too.
I did shut off the breaker and system to try and reset the the equipment. That didn’t work. When I do turn off for a few minutes and back on. Only the no flow lights up and after the normal time turns off and on goes the generating light for 5 secs than off. Power light never comes on.
I’ve checked the micro fuse on the pc and it’s not blown. The Thermistor that powers the board was not burnt and the board not scorch either. That was replaced a few years back by me
My question is. Do you think it’s the displays board that’s partially gone bad?
Thank you
Carl
Thank you
Carl
