I had a liner pool for several years. Chemistry control seemed easy.
I now have a gunite pool with pebble finish, SWCG and infinity edge with bubblers. The pool is 31,000 gallons. I use a full taylor test kit.
We only run the bubblers when needed to reduce aeration.
We only run the infinity edge enough to keep the chemistry up with the pool AND when swimmers are present to keep from overflowing.
Here are the things I am curious about and am wondering what others are seeing:
1. I was told I would be putting acid in the pool forever. So far that seems to be the case. (~10 oz every other day in the summer) I have given up on achieving 7.5 and look more at 7.7 as a sustainable target. This could play into #3 below.
2. I seem to need to regularly add calcium to keep that up (~4x per year). I adjusted it to 250 about 60 days ago and now it is at 200.
3. I seem to have to add baking soda regularly to keep the alkalinity up. I adjusted it to 100 sixty days ago and now it is below 50.
We have had about 9" of rain in the last two months.
I have not added a lot of other details here that may be necessary in order to keep this post short.
Do others with a similar pool set up see similar things? IF so what are your solutions? It may be that I just have to test often and make adjustments more often. I generally test pH and Cl every other day or so. But sometimes I just pour a bit of acid in the pool and call it good.
