I purchased this house 6 months ago, and I have some pool staining issues. It’s a 25k gallon gunite SWG pool with an infinity edge and trough.
This summer I did an AA treatment and it did a pretty good job. However the PH got away from me and I didn’t put enough sequesterant in and it came back, so I’m not trying round two.
I ran the chlorine to zero, and PH was 7.2. I put the filter on recirculate, and dumped in 2.2 lbs. it barely lightened up. I ended up throwing in almost 10 lbs of crushed vitamin C, but still a lot of staining except where I sprinkled it in directly.
I let it circulate for about 36 hours now and just checked again. No real change. My PH is bright yellow on the Taylor’s test kit. I put some viatamin C in a sock and put it directly Over a spot for 5 minutes. No change, like it didn’t do anything.
I just checked the skimmer bucket and it has visible iron looking stains on it still.
I hadn’t tested the sequesterant level, but last check several weeks ago it still had some. Is that causing the treatment to not work? Or am I just unbalanced in the water that bad? Or do I have some other staining going on?
I bought another 10 lbs of vitamin C but a little hesitant at to just throw more at it.
The pic of the steps has a storm holding my AA spot treatment down.
Chemicals:
Chlorine: 0
PH: Below 7.0
Alkalinity: 30
CH: 100
CYA: 30
Chemicals:
Chlorine: 0
PH: Below 7.0
Alkalinity: 30
CH: 100
CYA: 30
