I know this was talked about years ago but I wanted to bring it up again and the only thing that was mentioned was article 680 of the NEC. I read through it, looked at some diagrams and understand what it does. My particular issue is that my wire has been severed during concrete removal (seems common). But it continues on under the rest of the patio. I assume there is no way to replace the entire line. I noticed that the wire branches off via a metal clamp hooking two sections together. So I was curious if I could add a section of (proper) wire between my broken areas and clamp them together the same way? The annoying part was a portion of the wire was in the middle of the concrete, otherwise it would've been OK.
Thanks
Thanks
