I realize this is an old thread. The bonding and the grounding systems are connected at the pump. In the case of a double-insulated pump, the code specifically requires you to connect the bonding wire to the pump grounding wire.
Also, if the panel is at another building/structure a grounding rod is required by NEC. Many inspectors are known to consider a 4x4 post used to mount the panel on, a structure.
