Having our grotto designed this week. I was looking for some small twinkling RGB lighting which could go in the walls and ceiling of the grotto. PC mentioned fiber optics, I guess the bulb is changeable and it’s located down the cable. I’ve seen the SR Smith micro lights with premiere transformer that has 2 light show options, it’s costly. On YouTube there is the PoolGuy installing resin molded gemstones onto 12v LeD bulbs to create a “cave of treasures”. I know nothing about electricity. What can I use inside the grotto which will have multi colored lights? What else is a viable option with any limitations? How do these lights attach to the walls/ceiling? Silicone adhesive? Or do I have to have a niche? Or can I use spring loaded lights that fit into a hole or maybe into PVC pipe? Any help that isn’t too technical would be great! Thanks!
