That appears to be sand or debris.
You can try to attach a skimmer sock to the return(s) to see if you catch anything & prevent more from entering the pool. If you do catch some you may want to inspect your sand filter components to see if you have a cracked lateral or if the sand is at the right level. What model is your sand filter?
