Hi.
Just had the pool opened a week ago. The pool company shocked the pool and the water looks great. However, the are two problems. I’m not sure whether they’re independent, or not.
Thanks in advance for your help
Water temp = 76
pH = 7.2
TA = 70
CYA = 40
FC = too high to treat with AA, but dropping.
- Iron staining (confirmed with a vit C tablet)
I assume this is from our well water, combined with the high shock FC. We had a leak at the end of last season from one of the bottom drains, so after solving the leak we slowly filled from the well. I’ve ordered 5lbs of AA which will be employed once the FC level drops. I’ll also be using sequestrate for the future.
- Gritty “sand” that’s tightly stuck to the plaster.
Not sure whether this is coming from the well water, or elsewhere. We’ve had some weird weather recently, including a nearby tornado. The well water does go through a filter before it gets to the hose. Perhaps I should use a higher-grade filter (might catch iron as well as more grit)? The only way I’ve been able to get rid of it is using brute force. Wire brush or a drywall filler knife. It seems similar to this old thread: Gritty plaster
Does anyone have experience with such a problem?
Water temp = 76
pH = 7.2
TA = 70
CYA = 40
