I had 11,000 gallons of water brought in from a local volunteer fire department; it has been green since it left their tank and entered my pool. It is clear and the bottom can be seen. I had my water tested by the local pool store which recommended 3.5 lbs of Calcium Plus, 1/2 gal of Muriatic acid, 16 oz of Metal remover and chlorine tablets for my skimmer. I've done all of that including cleaning a very orange filter every couple of hours, letting the pump run 24 plus hours, adding 2 gallons of bleach, adding stabilizer, shocking twice, and using stabilizer tabs in my skimmer and my water is still green. The test from the pool store shows there is 0 Copper and 0 Iron in the water. It just rained but current testing levels are FC 3; pH 7.5; TA 120; TH 400; CYA 40. I know it is close to the end of the season but it's been 80 to 90 degrees for the last 4 days; any help will be greatly appreciated.
