- Jun 7, 2016
- 78
- Plaster
- CircuPool RJ-60
The pool was clear on a Saturday, then green by Wednesday; not horrible, but couldn't see the floor drain in the deep end. I'm not sure how it got so bad so fast, but when trying to shock it, it was burning through chlorine. I had to put in enough chlorine to get it to what should have been around 55 so that it would stay above shock level until I could test it the next morning. I probably added about 70 gallons of 10% overall (generally one gallon will increase FC for me by about 2.5 ppm); had to add 10 gallons twice/day for a couple days to keep it above shock, while also running the SWG at 100% vs. typically it's at 20-35% to maintain.
It finally died off; turned off the SWG completely, stopped adding chlorine, overnight test has the FC staying steady now for the last few days, but there's still a green tint to the pool. You can't notice in the shallow end, but do in the deep end. I can still see the floor drain clearly now, and the water itself looks clear not cloudy, but it's not crystal clear and blue like normal. I've had to SLAM it multiple times before, but it always goes back to perfectly clear once the FC levels off, even with the chlorine still high, so I'm not sure what's different now.
FC: 27
CC: 0
pH: 7.2
TA: 200
CH: 150
CYA: 65
Salt: 3800
Temp: 90
FC is still really high, we have a cover, so it takes forever to come back down after shocking unless I replace some water, which I don't love doing on well. pH is low, but I believe that's normal with the FC so high. TA is always super high but I can't get it down and have read not to worry about it if pH is normal and it's not causing other issues. Whatever happened seemed to burn through the CYA as well, not sure if that's normal, but it dropped down to 0 and it decreased as well throughout the shock process. Salt got down to 3200, just added a few more bags a couple days ago.
I believe pH will come up once FC goes down, but I've never had an issue with green tint before with FC high. We are on well, but had work done on the pool last year and water trucked in afterwards to fill it. We topped it off with the well, and have used the well water to top it off a handful of times since then; the pool hose goes through the water softener, which uses iron fighter salt, so it's not great water, but minimal sediment and hardness. After draining some to close it for winter, re-filling, and topping off, best guess I'd say 65% of the water is what was trucked in and 35% well.
Reading some other threads it sounds like high iron in the water could be the cause of the green tint, bug again, hasn't been an issue in the past with 100% well water so I don't know what would be different now with only 1/3 of it well water. Regardless, is there a good way to test that, or what can be done about it? Metal remover products? Should I drain some and top it off (with well) to get FC down and see if that helps before doing anything else? Could there sill be a contaminant even if it's not consuming the chlorine anymore?
I'll also note that the floor drain does not work; well, it used to be clogged, got it un-clogged when the work was done last summer, but there appears to be a leek in the floor drain as air comes in if I open that valve. Here and there we get some water loss, I assume leaking through a broken floor drain pipe, which could be part of the issue of what caused the problem in the first place if contaminants are getting into the water through that, or the stale water sitting in that pipe. Regardless, circulation in the deep end isn't great.
FC: 27
CC: 0
pH: 7.2
TA: 200
CH: 150
CYA: 65
Salt: 3800
Temp: 90
