Shirker
0
- Jul 2, 2014
- 752
- Vinyl
- Pentair Intellichlor IC-40
If you can get all of the solids out, you will probably be fine as long as you have access to a lot of bleach. But if you have high CYA, you might not have a choice, you may have to exchange some of the water. But you can't just drain your pool or you risk destroying your liner. Keep fishing out the sludge and then as soon as you get your test kit, post the numbers here.So with the pool being brown does that mean a different approach.
