My pool (22 x 12 x4.5' bestway about 7000 gal) turned this lovely shade of green about 2 weeks ago. Initially, it was an algal bloom (due to me not maintaining the chlorine level <-- using 1" clorox xtrablue tablets in a ChemConnect).
what I have done in the last week to try and battle the green (after just dosing chlorine, sweeping, and filtering):
- Constant filtration including a backwash of the sand filter
- 1 gallon of bleach (due to not having any shock --- since my order was delayed)
- sweeping
- Installing an intex pool return fountain to help provide better aeration (solar ones weren't cutting it, and the og setup didn't make the surface move due to the return being lower in the pool)
- 2 pounds of shock (Clorox 6-1 xtrablue2 shock) <- dosed over two days
- Last night - added 1.5 pints of MA to try and bring the pH down
*I did buy a pool vac that attaches to the intake, so that I could suck up any algae, but I can't see the bottom, so can't verify if it is doing anything.
I am not sure what I have here.
The test strip in the picture goes as follows from top to bottom with what I think the readings are:
Hardness - 250-450
Total Chlorine - 10-20 ppm (doing a titration/drop test the chlorine test comes out almost mt dew yellow)
Free Chlorine - 10-20 ppm
Bromine - 20-40 ppm
Alkalinity - 120-180
CA - 0-30
pH - 7.6 - 8.2
The chlorine value has been this high for about 4 days now, so I am not even sure if the green is algae at this point due to the concentration being more than enough to kill it.
Ideas? Recommendations? Looking for ideas before doing the hard reset of draining the pool and either starting fresh, or just have the family switch to a sprinkler for the rest of the summer and then try again in the spring.
thank you for any help yall can provide.
