I have been battling with the pool store on trying to get the green algae out of my pool. After 3 attempts and approximately 2 weeks of nothing but problems I found this site (TFP) and plan on firing my pool store!
Two evenings ago a used 4 gallons of pool store super shock. Thirty - six hours later the pool is still green as it was before. Below are my pool water test results from the pool store. (just ordered a TF-100 Pool testing kit)
Free Chlorine OVER 18.3 ppm
Total Chlorine OVER 18.3 ppm
Combined chlorine 0 ppm
PH 8
Hardness 146 ppm
Alkalinity 132 ppm
Cyanuric Acid 115 (OUCH)
According to the pool store CYA recommended range is 30 - 150 ppm. My research is different!
Sounds like I will have to drain a portion of of pool to lower my CYA, but should I continue to filter water until my FC and TC also lower.
Thank You
PH 8
Hardness 146 ppm
Alkalinity 132 ppm
Thank You
