- Jun 1, 2017
- 28
- Vinyl
- Autopilot Digital PPC1 (RC-35)
Our pool pump malfunctioned last year and over the winter stopped working. Summary is a green pool now. I purchased CYA and lots of liquid bleach (switching from regular 6% bleach to 12.5% bleach during the pandemic) and most recently using Calcium Hypochlorite shock from a different pool store. I had my CYA level up to 50 and required so much chlorine to reach the shock level that I've spent lots of time and money on chlorine additions. When I got relatively clear water, I tried to vacuum and sweep which stirred all the junk up and the pool water became cloudy. We use a skimmer sock and the sock would clog in a few minutes. I vacuumed to waste but dropped my water level too low in the process. The pool store recommended floc for vacuuming to make it easier to get all the muck out.
So now, in June, in SC, I still have green murky water. I fear that my attempts have not been followed through due to outside responsibilities and that I've thrown much $ down the drain on bleach treatments.
I just did a chemistry test. The pump was not running (not sure if that matters) when I took the water samples
FC = 0
pH = >8 (was too pink to match)
alkalinity = 70
CYA <30
Salt level is reading that we need to add 120 lbs of salt
Water temperature is 80 degrees at least
Calcium Hardness is 30 at the last test (I have calcium chloride ice melt to add once I get the rest of the pool set)
I need to regroup and review the slam method. Can anyone guide me back to clean water.
Thank you!
FC = 0
alkalinity = 70
CYA <30
Thank you!
