- Apr 15, 2021
- 17
- Plaster
- CircuPool RJ-60 Plus
Hello,
Below is my pool. Was beautiful about a week ago. Finally used the Taylor kit (K-2006-c) instead of the digital one (Safe dip 6 in 1). I plan to swap out the equipment this weekend, but think I should SLAM first. Is this order what you would recommend?
Chemistry levels:
My thoughts on order to fix this & replace equipment.
Thanks!
Chemistry levels:
- CYA 100
- FC 7.6 ppm
- CC 1 ppm
- pH 7.4
- Drain 60% of the water to target a CYA of 40
- Refill water & test CYA, FC, CC, pH
- SLAM given these test figures
- Install new equipment once the pool has stabilized and is sparkly clean
Thanks!
