Hi there,
The cap to the grease gasket valve broke and the screw is stuck in the hole. I’ve tried using the method from INYO pools by hammering a flathead screw driver into the valve, but that didn’t work. I also tried a screw extraction tool which didn’t work. The trouble I’m running into is because there are two filter pumps close by one another so there’s not too much space to use the tools properly.
Has anyone tried plugging one of these valves with a sealant? I tried dap aquarium sealant and the pressure blew the sealant off quickly.
Does anyone else have suggestions?
