Living here in SC (Near Myrtle Beach), we get lots of down pours that could last for hours which makes me run outside to turn valve to waste to drain water because the overflow pipe cant handle it and me becoming soaked even with raingear on plus running out at 1, 2 , 3 o'clock in the morning to make sure it doesn't overflow. So my plan is to put a T on the return side after the filter and underground and connect 2 inline irrigation valves. 2 because just incase 1 fails to close after I turn it off which wont cause it to drain the pool. This will work perfect especially if I'm not home. I can remotely turn on the pump and then turn on the valves.. Good idea or bad???
