With a green pool (after opening for the spring), should algaecide be used along with the TFP or BBB method? How about this algaecide? http://a.co/hutLgI3
Algaecides work better as a preventative than as a cure, in much the same way that cleaning with Lysol stops the spread of colds but drinking it after you have a cold doesn't cure it.
As for that specific algaecide: Heck no! It has copper in it. Bad idea. Leads to metal stains on pool walls, green hair on kids, and the extra expense of metal sequestrants. If you are a belt-and-suspenders type of person, then Poly 60 is the stuff. But again, it won't cure the green.
Bleach cures green. How to do it is explained in SLAM Process
