- Feb 15, 2017
- 767
- Plaster
- Pentair Intellichlor IC-40
My pool opened today (the pool store does it), and it was beautiful. it's always beautiful (except the one year my cover tore) but this was exceptional. Then they found a small leak at my filter, so they said they coudn't put chlorine in or turn it on. I dumped the chlorine in and called and begged someone to come out asap, because it's 80 degrees for 2 days and then down to 60. but the biggest thing is I can't heat the water without the pump on. so, what can I test in cold water? I wanted to test CYA so I could get that started in case they come tomorrow to fix it, but I don't think I can test in cold water. I always at at least 5 lbs, more like 8 or 10 i think. but it's scary to add CYA without testing! tell me what I should do right now, please?
