Hi,
I installed an 18' above-ground Intex Pool last year. I joined the forum for two reasons. 1. After a hard freeze this year, my pump started leaking at the top of the tank while running. In the American way, I shut off both valves from the pool and decided to deal with it in the spring. Now that spring is here, it's time to fix the problem. 2. I want to learn the best ways to remove algae and keep the pool clean.
After opening the valves to let water back into the pump, it immediately started to leak. Photo attached. The power is not on.
