- May 23, 2015
- 24,472
- Plaster
- Pentair Intellichlor IC-60
Calcium phosphate scaling is a non-issue in pools. Phosphate levels are measured in parts-per-billion concentration and most pools will have levels below 2000ppb (2ppm). As long as a pool owner maintains calcium levels in the normal range, there simply isn’t enough calcium and phosphate ion concentrations to overcome the solubility limit. It’s takes very high pH, and very large concentrations of both calcium and phosphate to cause scaling. The pool industry has an unfortunate habit of promulgating all sorts of chemical theories to explain problems and then incorrectly uses and confuses correlation as causality. When one actually looks at the detailed scaling potential for calcium phosphate precipitation, it becomes immediately clear that it is least likely to happen in your pool.
Phosphates are a macronutrient for algal growth, that’s it. If you lower phosphate levels, you make it harder for algae to grow and you limit their growth rate. That’s it. Chlorine sanitizes water very quickly and algae can not effectively grow in properly chlorinated water. Thus, phosphate removal is more of an insurance policy, line using algaecides, than a sanitation strategy. If phosphates are high in a pool, remediation might be worthwhile, but it typically requires knowing why the PO4 levels are elevated in the first place. Otherwise, you could simply be shooting yourself in the foot constantly trying to battle back phosphates.
