Hi,
I know there are a lot of Aquarite threads like this but I could not find one with the exact same symptoms.
It may be a coincidence but I had a new pump installed a month ago which increased PSI from 12 to 25.
GEAR
This is a Goldline Aquarite board with software r1.33.
Problem is the same with my old Hayward cell and a brand new Chlorinator Pro.
SYNOPSIS OF PROBLEM
Last time I checked a couple weeks ago the salt was at 3400.
Now LEDs show solid (not flashing) Check Salt and Inspect Cell. Salt reading and instant salinity stay at zero (0). There is a slight 'click' when switching to 'instant salinity' but reading stays at zero.
REPRODUCING THE PROBLEM
1. Turn on pump & SWG.
2. No Flow flashes for approx 2 mins.
3. Power & Generating show for approx 2 mins.
4. LEDs change to solid (not slashing) Check Salt and Inspect Cell.
Throughout all this salt reading and instant salinity stay at zero. There is a slight 'click' when switching to 'instant salinity' but reading stays at zero.
TROUBLESHOOTING TRIED & TESTED
Replaced 6-year old cell with a brand new Chlorinator Pro today but have the exact same symptoms.
The thermistor looks OK, and usually a thermistor problem has different symptoms (have successfully performed the thermistor repair twice already on this board).
Disconnected & re-connected all cables to/from board.
Removed display mini-board and re-connected.
Have left board in 'off' position for several days.
REQUEST
Please can someone advise.. is it time to suck it up and buy a new board? If so should I upgrade or look for the same board? Is there anything else in the box I should try replacing before the board?
Again, it may be a coincidence but I had a new pump installed a month ago which increased PSI from 12 to 25. Could that have caused such a problem?
Many thanks,
ft.
GEAR
SYNOPSIS OF PROBLEM
REQUEST
Many thanks,
ft.
