goldline Aqualogic ps8 aux switch problem
Mar 13, 2011
8
Had this system for maybe 8 years, had all the regular problems with the pcb and did most of the servicing myself.Now when I switch on the super chlorinator the aux switch 4 turns on also, which turns on lights around pool.I just can't figure out how this can happen.
Any thoughts would be a great help!!
Thanks
Do you have a AQL-PS-8-V?
It seems like there is a group function that turns on superchlorinate and other functions simultaneously.
Go to configuration and check the aux 4 setup.
Check for a group function setup assigned to an aux button.
Is this something that just started happening for no reason?
I don't know why it is happening.
You probably have to go through all configuration settings.
Maybe you can reset the configuration to default and then redo all configuration.
So, aux 4 turns on only when you activate superchlorinate but not when you push the aux 4 button?
Has anyone recently altered the programming or touched the wiring?
