- Jul 5, 2010
- 85
- Plaster
- Hayward Aqua Rite (T-15)
I can NOT turn off the filter pump from the panel. I have to throw the breaker for the pump to stop.
Other options, such as turning the cleaner or water feature on to off and back, function properly.
I pulled the panel cover off. Took some measurements with my VOM. The main board seems to be controlling the voltage going into the relay correctly: filter to On, 24v present. filter to Off, 0 volts. So I'm thinking the relay is defective.
Would y'all agree, defective relay?
And I have a couple of other relays positions that are not in use. I was thinking of swapping relays around, see if that clears the problem. Anyone know if all of the relays on the panel are the same?
Thanks all
Thanks all
