going from green to clear - FC does not seem to be dropping
moneytastesbad
26
Morgantown, WV
Hello, I fired up the filter and removed the cover on Monday. Following the instructions in the Swamp to Oasis thread, I added bleach. I tested a half hour later and had a FC level of 18 (using the TFTestKit). I checked again an hour later and it was the same.
I have added very little bleach since then, and my level is still staying around 20. It is barely dropping at all and I have yet to see it go below 18.
We have had a lot of rain the past few days, not sure if that has anything to do with it or not. The greenness is still at about the same level as when I started. Last year, using the same methods, my FC dropped dramatically each hour for the first few days.
Any ideas what is going on?
My other test readings:
PH 7.7
TA 100
CYA 40
Re: going from green to clear - FC does not seem to be dropp
Count yourself lucky. It is certainly unusual that your FC hasn't dropped (you're not running a chlorinator or SWG, are you?) but it should be easy for you to keep the FC where you want it for the duration of the process.
Wish I could explain it better but there is certainly nothing wrong with what's happening in your pool. It'll drop in time.
Dave,
My test kit is stored in a cool dark place. I got it late summer 2010. Should I replace any of my kit? Could I be getting inaccurate numbers because it is old?
When you backwashed, was the water exiting discolored or clear? It may just be a matter of time. I have read a lot about the Cl not being used much at all, and then all of a sudden it kicks in and starts burning up!
If you run the pump for a while, and the backwash is clear to start, it may indicate something with your filter, but I wouldnt go down that route yet!
