jark87
- Jun 5, 2011
- 1,184
- Plaster
- Jandy Aquapure 1400
After reading your post, I was curious, so I went and checked. No water at all coming out from the wand connections - just out of the holes where it’s supposed to.Do all your wands have a lot of water that comes out from under the wand where it rotates on the shaft? I assume there is no sort of o-ring there as it would cause a friction point but i seem to loose a good bit of water from under the wand that just runs down that pipe and down into the bottom tank.
