twillux
- Oct 20, 2020
- 50
- Plaster
- Hayward Turbo Cell (T-CELL-5)
No problem; I went through a lot of research setting mine up too.When you say spray wands do they actually spray. My wands have streams of water coming out when the fan is stopped. Does turning the fan on cause them to spray.
I really appreciate you taking the time to help me.
The fan has nothing to do with the wands. Water flowing into the cooler with enough pressure will cause the wands to rotate. As they rotate, water will stream out of holes along each wand and drip down into the basin. You’re right, it’s definitely a drip or stream, not a spray. The important thing is that water is clearly coming out of all wands, and most importantly that the wands are rotating between 7-12 revolutions per minute. You can time the rotations with a watch and count how many full rotations one specific wand makes in one minute. If you’re outside of the 7-12, you adjust the inlet ball valve to change the amount of water going into the cooler.
