- Dec 20, 2020
- 51
- Plaster
- Pentair Intellichlor IC-40
Hey all, looking for feedback on how the chiller's outlet should be plumbed.
I had a glacier chiller installed during the build of my pool recently. The PB plumbed the Chiller outlet port in front of the SWG, thus using the IFCS as the return back to the pool. The PB decided not to run a dedicated line back to the pool from the chiller (as the manual says for new pool installation) because the pool would chill faster using the IFCS.
I contacted Glacier because of a different issue, and they asked how the PB installed the chiller. They came back saying the outlet port should be plumbed in front of the main pump. I brought this up to the PB, and the PB pushed back on the Glaciers recommendation. I was able to get the PB and Glacier on the phone together. Glacier convinced the PB that the outlet should be plumbed in front of the pump because the pump in the chiller doesn't have enough power to get the water back to the pool.
The PB is supposed to come back to change the install based on Glacier's recommendations. This includes:
I am hoping those with a Glacier Chiller (or more experience than me, doesn't take much : ) can help shed some light on the plumbing.
If it helps, I will have the chiller automated with an IntelliCenter
- Adding two ball valves (one close to the inlet and one close to the outlet of the chiller)
- Move the outlet from in front of the SWG to the main pump.
- Add a three-way valve (I'll add an actuator later for automation) where the new T is in front of the main pump.
