Super quick background: I purchased a home ~ 3 years ago and inherited a pool with it. I maintained the existing pool service provider, and due to multiple issues, I’ve let them go and have assumed pool maintenance on my own moving forward.
Questions
- Pool is plaster and around 16.5k gallons. Add another few hundred extra gallons for the attached spa.
- It does have a salt cell on it, but I’m told that the cell is effectively not doing anything. No salt has been added to the pool since I moved in, and the existing service provider has been treating it as a non-saltwater pool.
- I am using the TF-PRO test kit.
- Free Chlorine: 0.15 (less than 0.5)
- Combined Chlorine: 0 (0)
- Total Chlorine: 0.15 (less than 0.5)
- pH: 8.4 (8.2)
- Total Akalinity: 70 (80)
- Calcium Hardness: 380 (600; big delta here…?)
- Cyanuric Acid: 5 (less than 30; I can easily see the black dot with a full tube)
- Iron: 0.1 (didn’t measure)
- Copper: 0.3 (didn’t measure)
- Phosphates: 1064 (didn’t measure)
- Total Dissolved Solids: 2500 (didn’t measure)
- Chlorine and CYA were both low. I put in a 1lb bag of their Chlor Brite product to bring both up.
- Alkalinity was slightly low. I added 2.5lbs of their Alkaline Up product.
- I was told to let things stabilize for a day before addressing the slightly high pH. I have purchased muriatic acid, but have not added that in, yet.
- Phosphates are high, but I just replaced my filters, and the Leslie’s representative mentioned that a phosphate remover would require a filter cleaning afterwards. They said I could ignore the phosphate levels for now if the pool is looking OK (looks great right now).
- They also noted that the Total Dissolved Solids are very high. Said this indicated the water is pretty old, and I will want to consider draining and refilling at some point if I start having issues that can’t be addressed through the usual maintenance.
- Free Chlorine: 1.5 (went up by at least 1ppm)
- Combined Chlorine: 0 (no change)
- Total Chlorine: 1.5 (went up by at least 1ppm)
- pH: 8.2 (solution looks darker and may be greater than 8.2)
- Total Akalinity: 100 (went up by 20ppm)
- Cyanuric Acid: Less than 30 (I can still easily see the black dot with a full tube)
Questions
- Anything remarkable or any red flags about the information above?
- Should I use some tabs to start bumping the chlorine and CYA simultaneously, or given the very low CYA, am I better off using a separate conditioner and sticking with the liquid chlorine?
- Alkalinity is right in the middle of the range that Leslie’s recommended, but I’m seeing other posts on here where folks will run it lower. Should I keep it at 100 and now address the pH by adding some muriatic acid?
- Any thoughts on the phosphates and total dissolved solids? I’m kind of ignoring both of those things for now until I get my other readings in check, and even then, I’m not sure if I’ll formally address until I start to see some problems.
- The only test that didn’t align with the results from Leslie’s was the Calcium Hardness. I’m going to circle back with another test from them and will do my own again, but let me know if a large delta might be common for some reason.
