I'd imagine you're going to want to get to 80 so if you feel comfortable, you can take it to that. Just remember you'll need to raise the min FC to compensate for the increased CYA.
When we had our Pebble Sheen re-plaster our CH went from 150 to 250 in a couple of weeks. The PB said don't add any CH increase due to this.
My situation is very much on the extreme side, but I started at 125 and am now at 800. It's been one year almost to the day... No good
The CYA and salt can be added at the same time...there is no issue.
Dump the salt in and let the kids have at it. It makes for some fun times!
Glad everything has worked out for you thus far.
Maybe start with 5 hours, 1250 RPM, and 50% on the cell. Test and adjust as needed.
Yes, this needs to get fixed as this is not the way the cell should function. Ideally it should only receive power when the pump is running to create an additional margin of safety if the flow sensor was to malfunction.
If the electrician isn't able/willing to correct it let me know and I'll walk you through rewiring it.
The transformer is hooked to a relay so it must be a programming issue. Are you using the data cable off the intelliflo and controlling all aspects of the pump through the EasyTouch?
The SWG should be powered off a relay that activates when the pump recurves a command to operate. There is no programming for the cell other than adjusting the output percentage.
With the pump off, one of the relays needs to be active in order for the SWG to be getting power. Are any of the lights on, F-8?
