Opened pool got it crystal clear. Tested water was low on cya added stabilizer. Last few days green spots showing up in different parts of pool. I have attached results of test done today. Any suggestions please help!!!!
You need to do an Overnight Chlorine Loss Test. Remember that 70 is minimum CYA for SWG. Follow FC/CYA Levels for SWG. Dont raise your cya until you pass the oclt because you will need to slam if not. Double check your settings on the Poolmath app for a saltwater pool. What is your schedule for the SWG?
At some point, your FC was too low and that allowed algae to slip in. The OCLT will confirm that but, since you see the algae anyway, a SLAM is in your future
Since you see algae, I would prepare to perform the SLAM.
You could try a short (and normally ineffective) version of the SLAM by elevating your FC to double the amount the charts call for and holding it there for about 48 hours. Brush ALL the green away and up into the water so the chlorine can kill it.
It might work. If the algae disappears and stays gone for another day or so, perform the OCLT to see if you got it all.
