I have to add some calcium and CYA to my pool before closing because the CYA is only 20 and the calcium is only 200. What is the best way to add these two chemicals so they will dissolve quickly in cold 65 degree water? I read online that calcium can damage the surfacre of your pool if it falls to bottom so I’m wondering if I should dissolve it in a bucket of water before adding it, instead of broadcasting it like is recommended on here. I also need to know if there is a way to make stabilizer dissolve faster in cold water. The last time I used it, I put it in a sock like is recommended on here and it took almost a week to dissolve. I need to get around 3 pounds to dissolve in 4 days so the CYA is back up to 40 before closing. I don’t want to close with a CYA of only 20 because I have a mesh cover that doesn’t block out all of the sun and I will have to drain water out which will dilute the CYA. If there is no way to get stabilizer to fully dissolve in 4 days, I’m wondering if I should use liquid CYA or Dichlor shock to increase the CYA instead.
