My home is equipped with a standby generator. Space and noise regulations did not permit a generator that would power the entire house. Instead, we took the "Essential Circuits" route. Living in Texas we made a decision when the house and generator were new, not to put the pool equipment on the standby generator. After the recent record breaking cold weather I'm now taking a look at putting the pool equipment on the load center that is backed up with the standby generator.
When I turn on everything that is on the generator circuit now, it draws about 40 Amps on each leg. The generator can provide 75 Amps. With the Intelliflo pool motor running and the boost pump for the Polaris also running, together they draw 9.5 Amps. As you can see, that total of about 50 Amps is still well below the 75 that the generator can do. However, as many of you know, an electric motor can draw 5 times it's running current in the first 1/4 second of operation.
I know that soft start capacitor's exist for air conditioners and other inductive loads that can eliminate the inrush current problem. Somewhere in my memory banks I have a recollection that the Intelliflo pump starts up slowly and this may avoid the inrush current problem. Does anyone know about this? Does anyone have experience running their pool equipment on a standby generator?
