- Jun 24, 2021
- 16,349
- Vinyl
- CircuPool RJ-60 Plus
Ask away! Here to help!Sorry, that I keep asking dumb questions
Here's the numbers for today: Free Chlorine: 6.5, Combined Chlorine: 0, PH: 7.8, CYA: 60, ALK: 100, Salt: 2600, Calcium: 150. My wife did shock the pool last night. It may be algae. There appears to be green colored bubbles in the skimmer a lot the past few days. We have put clarifier in the pool recently as well.The electrodes itself not. What could have happened is that you already had dissolved metals in the pool, and once your chlorine levels got up again those metals got oxidised by chlorine, maybe supported by high pH, and turned green. But it could also be algae, hard to tell without more information.
Did you add copper containing algaecides to the pool? Are you using well water?
To start, you need to post a full set of water parameters, tested with your kit. A photo could also help.
No stains, but there is green 'stuff' settling on the bottom of the pool. The FC count last night was 6.5 while this afternoon (around 1700) it was 4.9. Would metal stick to the sides of the pool? It seems weird to me that algae could survive with the FC count as high as it is. It's been above 5 for the past few days.I'd suggest to do an Overnight Chlorine Loss Test next to rule out or confirm algae. Make sure that you he SWG is turned off while doing that so it doesn't skew the result.
Do you have any stained pool surfaces that could indicate metals?
