Update: I finally got the warranty company to send someone out. He observed the broken pump. Still waiting to hear back from them on whether they think it's covered or not and how it plays out if I can actually take a $$ equivalent to any covered repair which is my hope.
In the meantime, I had ordered the Circupool combo 2.0hp pump and Edge 40 SWG and took the weekend installing it all (minus the wiring because I am thinking I'll need to run a 240v circuit over unless the electrician Tuesday gives me amazing news).
The old pump had leaked so long that the water had penetrated and caused lots of rust on rebar, and concrete spalling. Instead of trying to fix that area (and also because inlet on new pump was higher than old pump) I decided to install pump on the lower concrete, shimmed up with 1.25" bricks epoxied to the slab. That way I could make the height work.
Skimmer/main drain feeds 1.5in pipe but everything after that is now 2in. I put the SWG right in front of the flow switch just so I could get that last 90 down to existing pipe and leave some room to maneuver in there.
I made the decision to just completely disconnect the old heater (metal 1.5in plumbing) and not try to build in a future bypass. I think with a solar cover we will get plenty of use out of the pool and if we ever add a hot tub we can deal with it then.
So now it's just a wait until Tuesday and see what we have to do to get electrical run over to it.
I'm guessing my decisions on the plumbing may cause some head scratches but I'm hoping no one sees anything that is really brutal. Kind o annoying to have to step over plumbing to get to the timer/SWG panel. Maybe I'll build a platform in there to make it a little easier.
First time working with PVC so I'm hoping all my joints don't leak!
