So I opened my pool this year and have a ray pak gas heater. Have had it for 7 years. Use only in early around and late fall. Water temp was 61 when opener. Put heater in and water coming out of water fall does not feel hot like in the past. Had it up to 90 to heat fast. I took temp of water coming out of water fall and it was only 77. Why would it not come out hotter or closer to the 90 I had it set on. Is there usually a difference of 10-15 degrees from the pool water temp going i. To the water coming out?
