GJ, in Michigan with a 266 btu keeping water to 91 ish for am in a 24k gal pool, it takes me about 6 hrs of heating daily (overnight) at $.75 per CCF or about $1.50 an hour, $9/day or $270/ mo in summer. With my size of heater in my pool, I get about a degree an hour.
Yours should be less IF you use a cover, your night temp differentials are less, and if you don't mind letting it drop a few degrees from your high point overnight throughout the day - depending on your gas rate per CCF or therm
In fall/winter, I am running inside a dome for more - depending on month, up to about $400/mo, maybe $500 in the coldest parts of winter.
I do my heating in a dedicated run-up for morning physio using an automation schedule. For night swims, I might bump it up a few degrees, eg. Just run the heater while swimming. I've found this to be cheaper than when I used to let the heater just run to keep at a particular temp, aka Thermostatting.
I worked all this out in order to be able to run all year at high temps as economically as possible. The cover is a critical element, just so you know
