This was our 6th season closing, and every year, we're trying to find ways to make this faster for us. As you can see with my sig, we have a spa and IG pool. We drain the spa into the pool, and then drain the pool below the skimmers as the first steps of our closing process. Since we don't have a back wash or other exhaust port, my spouse has opted to just remove the top of the filter housing, remove the cartridges, and just let the pump overflow the filter house and wash all over the ground. I think this contributes to the erosion we've had under the equipment pad (It's sloooowwwwly slanting) and convinced my spouse to figure some way to attach our vacuum hose to the pump and dump the water farther out in the lawn. He didn't care for that this year, and thought it took too long (yeah compared to filter pump dump!) I know a bigger submersible pump is an option (We have a small cover pump we use to put water back into the spa at close) but it's way to small to move the 1500 gallons we end up dumping.
I was thinking we could find some larger hose that could have a union type fitting and connect it to the pump directly?
SOOOO, all that said for people who don't have a port to dump water from your pool, what do you do to lower your water level?
