- Oct 25, 2015
- 5,856
- Plaster
- CircuPool RJ-60 Plus
Appreciate all the insight. My takeaways from the last dozen posters is to:
- Lower/balance out the TA, pH.
- Minimize evaporation
- Consider a water softener
All these are in play. I got the TA and pH down and the flakes went down significantly. Evaporation is just something we’re going to have to deal with, unfortunately. The pump and waterfall run 12 hours a day (8 to 8). My wife and kids want the pool at 90 degrees during the winter (pool gets used daily). The pool is on the south side of the house with no screen enclosure so summer temps will hit high 80s easily. And I’m not terribly interested in covering the pool considering how frequently we use it. I’m very interested in the whole house water softener so we’ve reached out to Culligan and some other local shops.
Manny,
Looks like you've got your options lined up and I certainly agree that a cover is not a great option if you use your pool a lot. We're in the same boat. We use the pool and spa several times per week now and will soon be using it every day. One of the best things we did was to add the screened enclosure, not cheap but great value for us since it does yield some reduced windage and we have zero bugs so we often are in the pool in the early evening... just another option for your consideration.
On the softener option I found it's similar to the pool store issues we have for pools. Don't think there's a TFP type of site for water softeners but I would check the online sales sites before you talk to the local sales agents. The online sites offer sizing guides and information about options that will be good to know before you get the "hype". All the different manufacturers are very, very similar and all of the control heads are made by a couple of companies. I ended up buying a Fleck (one of the manufacturers of control heads). Install was simple and it's been in service for 5 years with absolutely no problems. Also, and again analogous to to pools I strongly recommend you test your water yourself. You can find a couple of services that will do this for you at a cost but it's all they do and they don't sell water treating equipment. I ended up putting an under sink RO unit in to remove small amounts of compounds I don't want my family to drink. Again, easy peasy to install myself. Drop tests are readily available so you can monitor performance also. I bought a Hach test for this and I test quarterly. So far every test result has been less than 1 ppm.
I hope this is helpful, and good luck!
Chris
