Hi,
I just opened my pool after the winter and sadly discovered that the water (under the cover) was dark green.
FC was at zero and CYA was < 20.
I SLAMed the pool using Cal-Hypo as I had a 50 lbs leftover from last year, and I need to increase the CH anyway.
I also added Muriatic Acid to bring PH to 7.4 and 3lbs of CYA.
This morning, the water is blue again, but it's very cloudy, especially on the deep side of the pool.
Here are the test results from this morning:
- FC: 7
- PH: 7.4
- CYA still < 20 (I guess it's still dissolving)
- TA: 60
- CH: 250
Is the cloudiness due to the Cal-hypo?
Should I just wait one more day and see if improves?
Or should I keep SLAMing?
Fabio
- FC: 7
- PH: 7.4
- TA: 60
- CH: 250
Fabio
