Now that the cold snap has come to an end (in the 40's today, water temp is still at 33 deg, rising slowly) , I just removed the tarp from the pool equipment to let it et some much needed sun and noticed that the pressure on the filter (Titan II Sand) is very high, like at 38 PSI)..My normal range is about 15-18. Not sure what to do here.. Water flow to the pool and spa seem "ok", a little less, but I am not running pump at normal speeds..
One thought I had is that there is frozen water in the in filter.. Would running the heater in the SPA help alleviate the pressure issue?
Any guidance would be appreciated..
