Freeze cycle
ERoy
3
Milton Georgia
Help! The pool builder and his sub changed our pent air system so that we could schedule the spa spillway to run separately instead of running all the time when the pool was running. Now the spa water empties out when it is running in freeze cycle and the jets just shoot freezing water at the spa walls and causing pebble to come off and ice to form. How do we switch back to original setting or fix this problem? Thanks
Ok. So I don’t believe you can manage Freeze Protection on the app. You need either the PC program (what I showed) or you must adjust it on the Easytouch screen.
Do you have a PC?
I take that back. If you have SLConfig app, that is how you setup the equipment. Download that.
