I looked this up and could not find anyone else asking the same question. I've been testing right at 7ppm FC and .5 combined every few days over the past few weeks in our salt water pool, using the TF-100 chlorine drop test. SWG has been set at the same 40% level the whole time when it runs and even after I've had to add a bit of salt once or twice after rain (had to drain down a bit) the chlorine numbers didn't change. The only time I've had to add liquid chlorine was once about 2 weeks ago when I was first getting the level up from only 2ppm and has stayed at 7 stable ever since.
This past weekend, we had heavy usage of the pool on Saturday and then Sunday it rained on and off. Back to sun today.
Did my tests today and kept getting 9 FC and the same .5 CC. How would FC rise 2 ppm if I haven't added or adjusted anything chlorine related at all since I last tested 6 days ago? All I had done was add 40oz of dry stabilizer one week ago to get my CYA from 50 to 70.
CYA was 75 today and tested at 70 6 days ago. pH was about 7.6 today and about 7.4 6 days ago. I did not add or change anything btw those two readings.
