Folks,
Last year when I installed the pool, I glued on a 1/8" foam insulation around the inside of the wall. But where the skimmer and return jet is, the foam is cut just like the liner. What I've noticed is some water seepage around the skimmer and the return jet. I'm wondering if its the foam insulation that is affecting the seal.
Was I supposed to cut the foam insulation back a little bit (like an inch or so around the circumference of the jet & skimmer) so that it did not interfere with the return jet and skimmer seal?
-J
-J
