Salt cell by themselves do not cause foam. I have no clue what it is , but it has to be something in the water.
Since you live in Texas, I assume that you do not close your pool in the winter. Is that true?
Are you just now turning on your SWCG for this year? If so, what did you add to the pool over the winter when the cell was off?
If you have been running the SWCG for a while this year, what did you add just before the foam showed up?
I like the idea of cranking the cell up to max for a few days, or adding more Liquid Chlorine, and see if the additional chlorine will get rid of the foam.
Since we have seen this a couple of times this year, there has to be a common link. I'd try a different brand of chlorine.
